Nie dziłające spryskiwacze
kamil880510
Auto: Golf 6 GTI
Engine: 2.0 TSI CCZB
Localization: Radom
Post autor: kamil880510 »
Koledzy w moim golfie nie działąja mi spryskiwacze szyb, zdjąłem zderzak i zauważyłem że we wtyczce nie ma w ogóle napięcia, nawet jak naciskam manetka, miał ktoś podobny problem?
Wrzucam skanowaniem mojego auta, moze cos pomoze:
Tuesday,21,July,2015,18:56:42:33490
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WVWZZZ1KZBW072934 License Plate:
Chassis Type: 1K (7N0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 25 2E 42 44 46 47 52 55 56
69 76
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
76-Park Assist -- Status: Cannot be reached 1100
Address 01: Engine (CCZ) Labels: 06J-907-115-CCZ.clb
Part No SW: 5K0 907 115 HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0040
Revision: AAH18--- Serial number:
Coding: 0403000C1C070160
Shop #: WSC 01357 011 00200
VCID: E7DB4DC7D6EF8626BAD-80B2
1 Fault Found:
001089 - EVAP Emission Control Sys
P0441 - 000 - Incorrect Flow - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 93018 km
Time Indication: 0
Date: 2003.14.08
Time: 16:57:56
Freeze Frame:
RPM: 759 /min
Load: 19.2 %
Speed: 0.0 km/h
Temperature: 93.0°C
Temperature: 43.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.589 V
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 143B600D892900FC281406E7911D0041310800
Shop #: WSC 80093 222 69422
VCID: 7BF381B7FA67B2C6CE5-802E
No fault code found.
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01006
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 7EF588A3E175A7EEE9B-802B
1 Fault Found:
9481200 - Coolant Pressure
B10AB F0 [009] - Too Low
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Mileage: 93127 km
Date: 2003.14.10
Time: 18:43:28
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
Component: BCM PQ35 H 103 0615
Revision: 00103 AD
Coding: 48480A3A8837F30044880080044B092447750088736D8D60648000200040
VCID: 38795EBB8BD159DE637-806D
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 18081 26 0512
Coding: 009795
Component: RLS 170810 05 54 0403
Coding: 0330AD
Subsystem 3 - Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
4 Faults Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 153
Mileage: 93127 km
Time Indication: 0
Date: 2003.14.10
Time: 18:43:27
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 Off
OFF
OFF
01504 - Bulb for License-Plate Light (X)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 2
Reset counter: 153
Mileage: 93127 km
Time Indication: 0
Date: 2003.14.10
Time: 18:43:53
Freeze Frame:
Term 15 On
Voltage: 14.00 V
ON
ON
Term 50 Off
OFF
ON
01496 - Bulb for Fog-Lamps; Left (L22)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 153
Mileage: 93127 km
Time Indication: 0
Date: 2003.14.10
Time: 18:45:12
Freeze Frame:
Term 15 On
Voltage: 12.80 V
ON
ON
Term 50 Off
OFF
OFF
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 153
Mileage: 93127 km
Time Indication: 0
Date: 2003.14.10
Time: 18:45:12
Freeze Frame:
Term 15 On
Voltage: 12.80 V
ON
ON
Term 50 Off
OFF
OFF
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JH4000PR
Coding: 5892140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 76E59083C945EFAEB1B-8023
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Serial number: 0034222
Coding: 830000
2 Faults Found:
227379 - Windshield Wiper Switch
B1145 07 [009] - Mechanical Failure
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 93127 km
Date: 2003.14.10
Time: 18:43:28
227387 - Windshield Wiper Switch
B1145 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 93127 km
Date: 2003.14.10
Time: 18:43:28
Part No SW: 5K6 920 871 HW: 5K6 920 871
Component: KOMBI H04 0406
Serial number: 00000000000000
Coding: 170B01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: F1EF239F202B4896E49-80A4
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 040810F1002168
Coding: EDA91F4E10021200000000
VCID: EDD73FEFF413AC76C01-80B8
1 Fault Found:
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Mileage: 93127 km
Time Indication: 0
Date: 2003.14.10
Time: 18:43:33
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218109099957
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1.rod
VCID: E7DB4DC71EEF8626BAD-80B2
1 Fault Found:
9463827 - Rear Right Treble Speaker
B1068 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 153
Mileage: 93127 km
Date: 2003.14.10
Time: 18:43:30
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 5K0 959 702 C HW: 5K0 959 702 C
Component: Tuer-SG 009 2117
Coding: 0004406
VCID: 3363699752B7BA86565-8066
3 Faults Found:
00940 - Mirror Adjust Motor; Passenger Side (V150)
012 - Electrical Fault in Circuit
00110 - Right Mirror Turn Signal Lamp (L132)
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial number:
Coding: 1444956
VCID: 34616A8B57B9BDBE4FF-8061
Subsystem 1 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Subsystem 2 - Part No: ID-R fehlt
Component: AFS-Lst.-Modul r ....
Coding: 00000255
5 Faults Found:
02234 - Right Headlight Power Output Stage (J668)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 153
Mileage: 93127 km
Time Indication: 0
Date: 2003.14.10
Time: 18:43:28
Freeze Frame:
Voltage: 11.93 V
Speed: 0.0 km/h
ABS 1
01042 - Control Module; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 153
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Ostatnio zmieniony 21 lip 2015, 21:18 przez marmi, łącznie zmieniany 1 raz.
Powód: pousuwał kawałki skanu bez błędu bo jest to długie i nieczytelne
