vdcs komunikat NO RESPONSE NOT CONTROLLER
R.T
Engine: 1.6 TDI 77 kw
Localization: podkarpacie
Post autor: R.T »
VCDS nie łączy sie z modułami 37 navigation 46 central conw ,56 radio ,przy próbie połączenia komunikat NO RESPONSE NOT CONTROLLER był tez problem z z 09 cent .elekt. ale teraz łączy się bez problemu wie ktoś jak rozwiązać ten problem niżej mój auto scan
Saturday,18,June,2016,03:15:34:0503561
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
http://www.Ross-Tech.com
VIN: License Plate:
Mileage: 163670km-101699mi Repair Order:
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
37-Navigation -- Status: OK 0000
56-Radio -- Status: OK 0000
-ddress 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 ML HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 9052
Revision: --H43--- Serial number: 00000000000000
Coding: 08114016032400080000
Shop #: WSC 00028 028 00022
ASAM Dataset: EV_ECM16TDI02103L906023ML 003005
ROD: EV_ECM16TDI02103L906023MK_SE36.rod
VCID: 7CF06CDFF7F8C0DE0A-8028
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 113B200D09290002880C04E890210041310000
Shop #: WSC 00028 028 00001
VCID: 7BF26FC3FAF6C7E603-802E
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 ES HW: 5K0 907 044 ES
Component: Climatronic H18 1112
Revision: 00001004
Coding: 0000004002
VCID: 0008182F9B10A43E56-8054
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 M HW: 1K0 937 086 M
Component: BCM PQ35 M 110 0651
Revision: 00110 AC
Coding: 40180A3A88241AC0400800C8740081E44B510288736D8520648000200040
VCID: 3A7CAAC7B54C3EEE58-806E
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 21101 26 0512
Coding: 009795
Component: RLS 101111 05 54 0403
Coding: 0230AD
3 Faults Found:
01500 - Bulb for Fog-Lamps; Right (L23)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 4
Fault Frequency: 6
Reset counter: 174
Mileage: 163493 km
Time Indication: 0
Date: 2016.06.09
Time: 17:03:36
Freeze Frame:
Term 15 On
Voltage: 12.45 V
ON
ON
Term 50 Off
OFF
ON
01332 - Door Control Module; Passenger Side (J387)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 3
Reset counter: 148
Mileage: 161913 km
Time Indication: 0
Date: 2016.05.20
Time: 16:23:35
Freeze Frame:
Term 15 Off
Voltage: 12.70 V
OFF
ON
Term 50 Off
OFF
OFF
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 148
Mileage: 161913 km
Time Indication: 0
Date: 2016.05.20
Time: 16:23:35
Freeze Frame:
Term 15 Off
Voltage: 12.70 V
OFF
ON
Term 50 Off
OFF
OFF
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5RAC5754
Coding: 00004431
Shop #: WSC 00028 028 00008
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: 316E8DEB603AFDB6E9-8064
Crash sensor for side airbag; driver side:
Serial number: 3572MSME7A180667ZZZ
Crash sensor for side airbag; front passenger side:
Serial number: 3582MSME00190667ZZZN
Crash sensor for side airbag; rear; driver side:
Serial number: 3512QSME54115F24ZZZS
Crash sensor for side airbag; rear; passenger side:
Serial number: 3522QSME50156307ZZZJ
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422KKC0000P
Coding: 1082140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 72EC42E7A5BC86AE50-8026
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-TK6 H06 0022
Serial number: 40000000000000508970
Coding: E20000
Part No SW: 5K0 920 872 A HW: 5K0 920 872 A
Component: KOMBI H03 0607
Coding: 170F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 2D56919B7C029956CD-8078
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 041111F1000401
Coding: 350002
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 5K0 857 511 B HW: 8P0 857 511 C
Component: FLA H04 0006
Revision: AA001002
Coding: 01018B6B74745D545420363E00
VCID: 2D56919B74029956CD-8078
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H03 0607
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6ADC5A878D6C4E6EE8-803E
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 H HW: 5K0 959 701 H
Component: Tuer-SG 009 2105
Coding: 0000180
VCID: 377AB3F3465E2386A7-8062
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
VCID: 346084FF5728C89E82-8060
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 5K0 959 702 E HW: 5K0 959 702 E
Component: Tuer-SG 009 2123
Coding: 0000436
VCID: 3566B9FB5C52D196B5-8060
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 00028 028 1012545
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0000144
VCID: 3664BEF74154DA8EBC-8062
End-------------------------(Elapsed Time: 02:42)--------------------------
R.T
Re: vdcs komunikat NO RESPONSE NOT CONTROLLER
Post autor: R.T »
Już wiem mk 6 nie łączy się z 46 bo jest w 09 ale co z 37 i 56 może jest to związane że nawigacja po włożeniu płyty nie działa tylko jest off road ,napisałem to w tu mk6-multimedia/rns-310-nie-dziala-navi-t4142.html
