link do niemieckiego forum : http://www.motor-talk.de/forum/rattle-1 ... ?highlight
koleś pisze że to hałasuje dwumas który mi ostatnio zmieniali
i tłumaczenie niemieckiego kolegi po angielsku :
The rattle noise ist generated by the double-mass-flywheel (ZMS).
The DSG clutch ist coupled with the ZMS by a big toothing. Additionally there is a tension mechanism to reduce the backlash of the tooting.
On some engines this tension is not strong enough to reduce the idle vibration of the engine, especially when the air condition and high electrical cosumption is active.
There ist nothing defect, and there are no damages to expect.
If the rattle noise is too uncomfortable, you should contact your local dealer for an analysis of the noise, a new ZMS (perhaps with optimizations) can eliminate the noise.
