byłbym wdzięczny za jakąkolwiek pomoc
Kod: Zaznacz cały
Address 01: Engine (CBD) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 MC HW: 03L 906 022 G
Component: R4 2,0L EDC G000SG 3593
Revision: 13H01--- Serial number:
Coding: 0000071
Shop #: WSC 00110 216 87783
VCID: 72EB3C436D5AFA8E927-8027
2 Faults Found:
049489 - No Communications with Airbag Control Module
U0151 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 110604 km
Time Indication: 0
Date: 2009.14.14
Time: 23:24:16
Freeze Frame:
RPM: 0 /min
Voltage: 11.78 V
Temperature: 4.5°C
Temperature: 38.7°C
Bin. Bits: 00000000
Torque: 108.0 Nm
Temperature: 18.9°C
049508 - No Communications with HVAC Control Module (J301)
U0164 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 110604 km
Time Indication: 0
Date: 2009.14.14
Time: 23:24:40
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Temperature: 4.5°C
Voltage: 11.78 V
Bin. Bits: 00000000
Torque: 108.0 Nm
Temperature: 18.9°C
Readiness: 0 0 0 0 0
Kod: Zaznacz cały
Part No SW: 1K0 937 086 HW: 1K0 937 086
Component: BCM PQ35 M 020 0358
Revision: 00020000
Coding: 48180A3A9825F3C040080080540081E445710088736D8D60648000000000
Shop #: WSC 00028 028 00001
VCID: EDD1AF3F3464A576CF5-80B8
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 06030 21 0501
Coding: 009795
Component: RLS 160309 05 54 0402
Coding: 0330AD
Subsystem 4 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 204
Mileage: 110604 km
Time Indication: 0
Date: 2009.14.15
Time: 00:20:19
Freeze Frame:
Term 15 On
Voltage: 14.00 V
ON
ON
Term 50 Off
OFF
OFF
00059 - Terminal 30 for Interior Lighting
Freeze Frame:
Fault Status: 00101011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 244
Mileage: 110604 km
Time Indication: 0
Date: 2009.14.15
Time: 00:25:19
Freeze Frame:
Term 15 On
Voltage: 14.10 V
ON
OFF
Term 50 Off
OFF
OFF
